TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Your fluid is low. Make sure to use ATF Type III
Subject Re: Re: Your fluid is low. Make sure to use ATF Type III
Posted by Caveman on January 06, 2011 at 8:13 AM
  This message has been viewed 154 times.
In Reply To Re: Your fluid is low. Make sure to use ATF Type III (n/m) posted by Caveman on January 06, 2011 at 07:57 AM
Message Doug8867 and Stadsport,
First off, thanks for the quick response... I wish it were just the fluid.. With all of Doug's advise in mind, about 4 months ago when it was still about 30 deg C or more here in San Diego I tried even filling the thing as full as it would go thinking the fluid was just thinning out at temp. I have checked the level on several occasions to @## bleeding detail using a syringe to ensure proper float level at the hottest temps. And there are no leaks.
Another thing is that it was never on BEFORE I had the performance parts installed (maybe a correlation, maybe not). I called the technician about the light on my way home and he said to check the level, which led me to the steps listed above.
It is interesting though; everyone always leads this back to the fluid level.. Maybe the float circuitry from the stick went bad? What do you think?
Thank again
